My wife's 2007 GX470 was having battery drain issues.  I tracked it to the little lights on the power window switch never turning off.  I pulled it and it looked like an aftermarket unit.  I bought another aftermarket unit and sure enough, I had the same problem.  Has anyone had any luck with replacing these with something. Non-OEM?  I'm not paying almost $700 for that part from Lexus.
Hello, Justin. Have you already tried reprogramming the power windows?
  1. Turn the key to the on position.
  2. At each window switch, lower the window to halfway, then immediately raise it all the way up and hold the switch up for at least 1 second.
  3. Repeat this process for all 4 doors
    Also, you may get lucky in finding a wrecked GX470 at a scrap yard.
Thanks!  I have done reprogrammed the windows for sure.  I'm going to start looking at a junkyard, but it'd be awesome to find an aftermarket.
Edited by JKSims
  • Like 1
