I am me here and just came into possession of a 1992 SC 400 with 13,000 original miles. The vehicle has been garage kept but runs a bit rough. I spoke with my mechanic about the situation and was told to replace the timing belt before I do anything. He states that due to the age alone it’s very likely to break. I have been told by others to leave well enough alone. Please, someone with more knowledge than me help. Is this something I need to worry about?
I would install a new tb and all the crossover parts involved. Plugs, Clean the fuel system etc...Change all fluids, Brakes, Radiator etc...Lot to be done but worth it on a 13000 mile SC400
32 years old, your mechanic is spot on. New belt, water pump and tensioner.  You can buy the complete kit, OEM Aisin parts, from Rock Auto for a good price. Your mechanic will charge you about 8 hours for the job. Plugs should be fine, but i would do coolant, oil, filter and brake flush just becuase of the age, unless you know when they were last done. A few treatments with in tank injector cleaners and a then new fuel filter would also be a good idea.
  • Like 1
I figured as much but I’m glad I asked. Thanks
