Freeze plug cover leak
Simple jib to fix. Most lexus the freeze plug is held on by two small bolts. Remove them, take the cover off and clean it up. Put is back on with a silicone bead on it. You will need to drain coolant amd put it back in, or replace it if it is due. Only use the proper Toyota long life antifreeze.
