Radio Reception
Sloan55
I live in Canada and recently bought a 2001 LX 470 out of an auction in Miami. After getting it back here, I noticed that the reception on the radio is aweful. I have checked the usual suspects (antennae, wires etc...) however I can't get anything in. Even my local stations sound like they are 1000 miles away. Does anyone else in Canada have this problem?
Reception problems could be due to XM radio. I had XM installed in my 2004 470. I noticed that my radio would static out at times. I finally found out that if you have an XM tuner (they are all at this time through your fm radio) you should turn it off while not using XM. It will always be trying to transmit over your stations.
