IslanderGX470 Posted September 16 Share Posted September 16 Hello, I am a new member and this is my first post on this forum.聽 聽Hopefully I am posting in the correct place.聽 馃檪聽聽I decided to test my flat key after eighteen years and followed the owners manual instructions on how to use it with the transponder chip.聽 It did not work, so I tried multiple times.聽 I then tried the valet key and it didn't work.聽 My next and last step was to use my master key which was working fine.聽 That did not work.聽 I tried all three keys multiple times again.聽 It just clicks and the dashboard lights up as shown in the pic.聽 I can roll the windows up/down, lock the doors but it won't start.聽 Did I accidentally activate the engine immobilizer by using the transponder chip in the flat key case?聽 Any ideas what I can do?聽 聽 聽 聽 Quote Link to comment Share on other sites More sharing options...
RX400h Posted September 17 Share Posted September 17 There could be several reasons why your Lexus GX470 is not starting with the flat key and transponder chip: Wrong Key: You might be attempting to use a key for a different vehicle1. Locked Steering Wheel: If the steering wheel is locked, you can unlock it by turning the steering wheel from left to right while simultaneously turning the ignition key on1.聽If this doesn鈥檛 work, it鈥檚 recommended to have the vehicle towed to a Lexus dealership as the key may be worn/damaged or there may be a problem with the ignition switch itself1. Battery Issue: If you recently changed or disconnected the battery, your Lexus may not start because it has lost synchronization between the key and the vehicle2.聽You can try pressing the Start button with the keyfob2. Key Battery: The battery in your key might need to be replaced3. Error Code: If an error code is preventing the vehicle from starting, you can try clearing the code with a code reader or by disconnecting the negative terminal for 5 minutes4. If none of these solutions work, it鈥檚 best to consult with a professional mechanic or your local Lexus dealership for further assistance. Quote Link to comment Share on other sites More sharing options...
IslanderGX470 Posted September 17 Author Share Posted September 17 15 hours ago, RX400h said: There could be several reasons why your Lexus GX470 is not starting with the flat key and transponder chip: Wrong Key: You might be attempting to use a key for a different vehicle1. Locked Steering Wheel: If the steering wheel is locked, you can unlock it by turning the steering wheel from left to right while simultaneously turning the ignition key on1.聽If this doesn鈥檛 work, it鈥檚 recommended to have the vehicle towed to a Lexus dealership as the key may be worn/damaged or there may be a problem with the ignition switch itself1. Battery Issue: If you recently changed or disconnected the battery, your Lexus may not start because it has lost synchronization between the key and the vehicle2.聽You can try pressing the Start button with the keyfob2. Key Battery: The battery in your key might need to be replaced3. Error Code: If an error code is preventing the vehicle from starting, you can try clearing the code with a code reader or by disconnecting the negative terminal for 5 minutes4. If none of these solutions work, it鈥檚 best to consult with a professional mechanic or your local Lexus dealership for further assistance. Thank you Dave for your response.聽 I went through these steps: 1) The key is the correct key.聽 I tried all three keys - master, valet and flat key with chip transponder in the case 2) I tried this and it still just clicks when I try to start it. 3) I just had major repairs done the day prior, but everything worked fine until I tried the flat key with chip transponder.聽聽 4) The battery was recently replaced and it worked fine until I tested out the flat key to see if it would work.聽 5) I disconnected the negative terminal for 15 minutes, reconnected and it still just clicks when I try to start.聽聽 I believe this may be related to the flat key/chip transponder.聽 The moment I tried it and it did not work is when all keys stopped working.聽聽 It sounds like my next step is to have it towed to my Lexus tech where I had the repairs done and get this figured out.聽 聽 Thanks again for your advice and guidance.聽 聽 Quote Link to comment Share on other sites More sharing options...
RX400h Posted September 17 Share Posted September 17 I'm sorry none of those tips worked, Doug. It is perplexing to say the least. Quote Link to comment Share on other sites More sharing options...
