Electrical system malfunctioning on ES330
timmm
The electrical system on my 2005 ES330, 220,000 miles, has stopped operating.  When I try to start it, nothing but "check engine" light comes on.  Everything else is completely dark.  Remote starter starts the engine, but then I have to shift into gear using the override button.  Any ideas what's wrong?
I find it interesting that the car starts with the remote which indicates the engine and that portion of the system is OK. Does anything else work when it's running ?
Perhaps the remote starter is causing the issue. There should be a manual override switch to disable it. I would try shutting it off and then starting the car normally. Also maybe something as crazy and simple as changing the battery in your remote FOB ? Otherwise might be something in the ignition switch or steering column like loose connector ? All I have to offer offhand ....not a mechanic 😞
