Aloha folks, looking through used rims and tires, how can I know what will fit my 2007 ES 350. I think that it is supposed to have 17"
thanks   Ed
Factory size is 215/55-17
You can look up this information, including wheel sizes that match the tires by going to www.tirerack.com.
an 8-inch width (17-inch) wheel with +40 offset appears to be OEM sizes.
You can also call the experts at Tirerack if you have any questions.
Thanks guys, but if I see a set of 17s from a Toyota or Ford with rims, will they bolt onto my Lexus? I am looking for used tires and rims.
Ed
They should have the same wheel bolt circle pattern, but the width and offset may not be the same. If you find some, perhaps ask the owner for the year and model of the vehicle they came from. Then you can plug in that information in Tirerack's website, which should reveal the information you will need to compare to the those for your vehicle.
