momses300 Posted November 1, 2004 Share Posted November 1, 2004 Does anyone out there have recommendations, proceedures, etc for diagnosing slipping and o/d problems on the early (94) es300 ? I've been to the dealer, gotten the "lets replace the whole thing for $3800", have installed a used (60K miles) transmission, and still have the same no overdrive symptoms. Codes I've gotten are P1600-computer battery backup, P0720-output speed sensor, P0500-vehicle speed sonsor, P0100-airflow circuit, P0110-intake air temp. I've been working out of a Haynes manual (97 and later toyota), gotten myself pretty confused, and would like more accurate diagnostic procedures. Does anyone out there have a factory manual that could help ? Mayday...Mayday....any station come in please!! Bill Quote Link to comment Share on other sites More sharing options...
SKperformance Posted November 2, 2004 Share Posted November 2, 2004 You have a few problems if you get that many different codes. I would start by checking the wiring for animals chewing through wires. Quote Link to comment Share on other sites More sharing options...
mztrmarcus Posted November 27, 2006 Share Posted November 27, 2006 My 1995 ES300 is displaying similar symptoms (no speedometer/odometer reading, O/D lights blinking when O/D should be on, CEL on). OBD test results in codes P0500 and P0720 both of which lead me to suspect the Speed Sensor on the transmission is bad. However, I am having some doubts because I am getting 2 codes instead of just 1. Do these 2 indicate an electrical problem from the sensor the the computer box? Is there a way to test the Speed Sensor? Can I attach it to a drill and spin the gear to check if it's working? The sensor costs somewhere in the neihborhood of $170 off the www and off course they will not accept returns if I find that changing the sensors doesn't fix the problem. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
mztrmarcus Posted November 30, 2006 Share Posted November 30, 2006 My 1995 ES300 is displaying similar symptoms (no speedometer/odometer reading, O/D lights blinking when O/D should be on, CEL on). OBD test results in codes P0500 and P0720 both of which lead me to suspect the Speed Sensor on the transmission is bad. However, I am having some doubts because I am getting 2 codes instead of just 1. Do these 2 indicate an electrical problem from the sensor the the computer box? Is there a way to test the Speed Sensor? Can I attach it to a drill and spin the gear to check if it's working? The sensor costs somewhere in the neihborhood of $170 off the www and off course they will not accept returns if I find that changing the sensors doesn't fix the problem. Thanks in advance. I found a way to test the speed sensor by back probing the connectors and turning the wheel which should result in a change of voltage between 0 to 11 volts. I found that my sensor is in fact busted so I called Lexus for a replacement part. Glendale Lexus said they had it in stock so I went there to pick it up. When I got there, the part that they were giving me was totally different. They had part number 89413 which was a black plastic sensor which had a diameter smaller than mine (physically not substitutable from the original). So I showed them a picture of my speed sensor (taken from the part manufacturer's website: http://www.smpcorp.com/web_app/catalog/smp_bgbulk.aspx) part number SC149. They said this part is superceded with the new one. Duh? Anyone have information on the part number I am looking for? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
cldriscoll Posted October 8, 2011 Share Posted October 8, 2011 i have error codes p0500 and p0720. I work at a major motor parts warehouse and the guys in the showroom narrowed it down to needing a standard sc149 or sc153, but im stuck with a 50/50 chance of wasting $100 or $200. Quote Link to comment Share on other sites More sharing options...
