Stereo Wiring Diagram
I recently bought a 95 SC400. I have a problem with the Stereo (Nakamichi). Very little sound comes from the rear speakers. I've read that water can get in (thru the gas door drain) and get things wet. I've removed the amp, and it wasn't wet. I'm wondering if anyone has the wiring diagram they could send me to help trouble shoot the problem.
Thanks in advanced,
John
juribe@beasly.com
If it helps any, I had water come in through my gas door drain like many and it fried my amp...Lexus replaced it for 200 with warranty and everything works great. If you haven't, take apart the trunk surrounding the cd changer and check below the amp to see if there is in fact water. In my case, the amp fried completely leaving no sound at all, which I think is what usually happens. www.carstereohelp.com should help you if you need to get to the amp. I'm not at my home computer right now or I would send you a flash program with the wiring diagram on it...I'll send it to you tomorrow if I find it.
