Fix Es300 Window Switches For Free!
jahon
I figured this out for myself. All i had to do was remove the window switch from the door panel, remove the switch cover on top, and underneith there is a square white box with a hole in the center for moving the window down. Spray WD40 down the small hole and put the switch cover back on top. Then plug it back into the car and move the switch up and down a couple times and it will begin to work like new! This saved me a fortune instead of buying all new switches... Let me know how it works for you because it worked for all of mine!
