Hi,
My Wifes RX 300 (2K model I believe) has these codes and they read kind of cryptic..... A/F sensor I assume is a 02 sensor???? Anyway I have P1130 P1135 and P1150. Is this a common problem? Is there a usual fix? Car just turned 60K miles....
TIA,
Bitsbucket
Codes P1130 and P1135 refer to the Air/Fuel Ratio Sensor, also called the Bank 1 Sensor. Check some of these RX forum threads from back in August and September, and you'll read much more about what to do and how to do it.
