Travieso~13 Posted October 5, 2004 Share Posted October 5, 2004 Hey whats up to all you peeps again!!! Congrats on the new look...lookin good! I seem to have a problem yet again...when I drive @ about 40mph and over, I noticed that there is air coming in through the front dash. I thought it was coming from the window but I realized that it's coming through the vent on the dash near the window, the one where the defrost comes through. Does anyone know what might be causing this? Does anyone have any suggestions as to what I can do to solve this? It is very annoying, I have to turn up the radio to not hear it. Once again thanks for all your help and suggestions, Traveiso~13 Quote Link to comment Share on other sites More sharing options...
silvermate Posted October 5, 2004 Share Posted October 5, 2004 you might want to check the rubber gromit around the air duct from the door jamb to the car it might be cracked or broken also check the the air duct for cracks or breaks Quote Link to comment Share on other sites More sharing options...
Travieso~13 Posted October 5, 2004 Author Share Posted October 5, 2004 Thanks i'll check that out today when I get home Quote Link to comment Share on other sites More sharing options...
wwest Posted October 7, 2004 Share Posted October 7, 2004 The dash air outlets on the far left and right of the A/C system are NEVER closed, always open to system airflow, unless you close them manually. I have found that if they are almost closed but not quite then they are noisy. Quote Link to comment Share on other sites More sharing options...
Travieso~13 Posted October 7, 2004 Author Share Posted October 7, 2004 The dash air outlets on the far left and right of the A/C system are NEVER closed, always open to system airflow, unless you close them manually. I have found that if they are almost closed but not quite then they are noisy. ← Thanks, So that would explain the noise at high speeds? By the way how would I go about closing those? Do you have yours closed? Where should I look? Once again thanks for your help travieso~13 Quote Link to comment Share on other sites More sharing options...
