after a jump start..(my fault) battery ran down  .. now no speedometer or guages
Did you buy a new battery ? Try disconnecting the neg. terminal for 20 min. and reconnect and start the car. Make sure your dim switch is turned all the way to the right .Hope this helps you. B)
THANK YOU THANK YOU THANK YOU..I WAS ABLE TO FIND FUSE...UNDER HOOD.. BY BATTERY..AND THE FUSE WAS NOT BAD BUT WAS ..TRIPPED.....I'M A GR. GRAMMA AND EAGER TO TAKE CARE OF CAR MYSELF... :rolleyes:
