smallbobwood Posted September 20, 2004 Share Posted September 20, 2004 ok - trying to save a few coins and change the oil myself. The question comes in how to remove the oil filter without creating a mess. My first glance is it is hard to get my hands on, and any oil leakage will spill all over the metal pan/shield underneath it. Also any idea of the size of the oil drain bolt? Thanks, Bob Quote Link to comment Share on other sites More sharing options...
randy20g Posted September 20, 2004 Share Posted September 20, 2004 Bob, you have to take the plate off. It comes off it 2 min. Quote Link to comment Share on other sites More sharing options...
smallbobwood Posted September 20, 2004 Author Share Posted September 20, 2004 I thought the plate would have to come off, but at first glance was not sure how easy/what to take off Quote Link to comment Share on other sites More sharing options...
silvermate Posted September 20, 2004 Share Posted September 20, 2004 drain the oil first with your drain pan underneath......leave the filter on after all the oil is drained outta the oil pan, screw the drain plug back in move your drain pan underneath the oil filter......(i use a piece of sandpaper to unscrew the filter) then let the rest of the oil drain out............put new filter in.......put new oil in. goodluck Quote Link to comment Share on other sites More sharing options...
smallbobwood Posted September 20, 2004 Author Share Posted September 20, 2004 duh.... that's obvious, I was not asking about oil change 101. The issue was if there was a trick to removing the filter and not creating a mess or if the entire plate had to be removed. Quote Link to comment Share on other sites More sharing options...
silvermate Posted September 20, 2004 Share Posted September 20, 2004 sorry jerk.......didn't know if you knew oil change 101 or not Quote Link to comment Share on other sites More sharing options...
Great White Posted November 30, 2004 Share Posted November 30, 2004 Yo Bob, I don't know if you take your rig to the dealership for maintenance, but my Toyota dealership changes the oil/filter in my Sequoia for free. If you are determined to do this yourself, you can try what I used to do on my old Chevy. After draining the oil in the pan, place the catchpan under the filter. You might want to put down some newspaper under the catchpan in a large enough area to absorb any oil that might splash out. Then take a medium size nail and tap it in the bottom of the filter with a hammer. When you remove the nail, most of the oil will drain out into the pan. After the oil slows to a drip, then remove the filter. Please wear safety goggles and good luck. Quote Link to comment Share on other sites More sharing options...
