Just wondering about any hints as to why the temp stays hot on the 300ES at times and works fine other times,any hints? Compressor is running but blowing hot air!
It sounds like you have the all too common problem of a sticking expansion valve. Do a search. This problem has been discussed numerous times.
I am not sure that you get a stored error code for this problem. A code was not stored when my 94 ES had the problem.
I know using my snap-on scanner I can view the coolant temp at any time. Are you going by the dashboard "moron gage"? It could be a faulty sending unit (sensor). I can monitor the coolant tomorrow and tell you what I get..
