Just wondering if someone could point me in the correct Re & Re of the fog lights.
Do I remove the inner fender well & go from there ? Or go in from the bottom ?
Thanks in Advance
MC
I found on my ES it was easy to jack up and support the front end, remove the splash guard and go up from the bottom. When I changed out the bulbs for my ES fogs, the mounting hardware for the fog light itself was right there. The IS may be similar.
steviej
  • 1 year later...
if u stick your hand in the scoop right next to the fog light on the outer side u will feel two screws. or u can also look and see. all u need is a ratchet wrench, 10mm that short enough to fit in there. and you can losen those two screws and pull it out. but be carefull when using the ratchet make sure u dont hit the paint.
to me thats the easiest way because of the fact u dont gotta remove anything else.
dude, you are responding to a thread that hasn't been active for over 16 months. your have done this in many threads all in one morning. chill out a little, I know you just got a new car and your excited, but enough is enough. You are waking up dead threads.
On the other hand, Welcome to the club,
steviej
ES/IS Forum Moderator.
haha really? damn i havent even paid attention to the dates. i gues si posted alot of replies cuz im looking for alot of information. my bads man.
