Ls 400 Brake Upgrade
axis8758
I wanted to ask if anyone is running the LS 400 brake upgrade on their sc300? I have a set of 98' LS 400 4 piston calipers and tried to install them over the weekend but found that the holes didn't line up. If any one else has this set up did you have the same problem? How did you fix it? Thanks in advance.........
