axis8758 Posted August 30, 2004 Posted August 30, 2004 I wanted to ask if anyone is running the LS 400 brake upgrade on their sc300? I have a set of 98' LS 400 4 piston calipers and tried to install them over the weekend but found that the holes didn't line up. If any one else has this set up did you have the same problem? How did you fix it? Thanks in advance.........
Caanon Posted September 8, 2004 Posted September 8, 2004 If a search here doesn't work to find any info, you can try searching first, then asking at clublexus http://www.clublexus.com/forums/forumdisplay.php?forumid=6 Quite a few people there have changed to 95+ LS400 brakes.
