i don't know why....
my Engine light was ON...
after i carry to Company checking..
they r telling me the Sensor no Work..
What Should I Do.....
cause i'm not living in State...
one Sensore going to Cost me 450US....
what should i DO......
did they tell you what sensor was bad or not working (there are a many sensors in the car? My guess it was an O2 sensor. If it was, these are easy to replace if you know which one is faulty or totally not working.
Several sites on the web sell these parts for a fraction of the cost it would be from the dealer direct.
Do you know what trouble codes were read from the Check Engien Light?
steviej
I recommend you go on ebay and buy yourself a obd2 scanner and find out your engine codes since you have no warr and se it to find out what is wrong.This way you can post them here and we can hel if possible.
Thank U all....
i think i have to go the Garage Again....
make sure which one is not working...
It's O2 Sensor......
but the Mechanic did tell me...
if i change that one...
if the light still ON...
then i have to Change 3 of THEM!!!!!
that's a Head Ache u know....
Cause i'm living in Central America...... Belize.....
So i have the Only 1 IS300 in this Country........
Everything Expensive here.....
Headache......
the trouble code will tell you exactly which one of the O2 sensor is faulty.
each sensor will generate a different number code.
See if the mechanic can give you the exact code, for example P1135 is the code for the O2 sensor located at (Bank 1 Sensor 1).
sk has a good suggestion. you can get a scanner online for about $100 USD. This will save you the diagnostic fees in the future.
think about it.
steviej
Thank U STVIEJ
I HAVE A QUESTION....
U SAY...I CAN GET A SCANNER ABOUT 100 US???
IS THAT TRUE???
WHEN I CAN GET IT??
U HAVE ONE???
I have a 2001 Is300 and the diag code states i have a bad o2 sensor. Which one is the Bank 2, Sensor 2 Oxygen Sensor? There are 2 o2 sensors on the manifold, 1 behind it near the catalyt coverter and 1 on the rear exhaust pipe. Which one do i replace?
IS THAT TRUE???
WHEN I CAN GET IT??
U HAVE ONE???
you seem to be computer proficient, search the web.
try different places like www.autozne.com. www.summit.com, www.jeggs.com
most online autoparts stores carry them, they should be able to ship international.
check them out.
steviej
