ROBKOWSKI Posted January 18, 2023 Posted January 18, 2023 My 2008 RX400h with 136,000 miles uses a quart of oil at about 1500 miles. No leaking is occurring and I do not see any smoke from exhaust pipe. The oil was changed every 5,000 miles since new. Anyone else have this issue? Car runs and drives great.
RX400h Posted January 19, 2023 Posted January 19, 2023 Are you the original owner? Our RX400h engine uses no oil. It's oil was also changed every 4500-5000 miles with synthetic oil.
ROBKOWSKI Posted January 19, 2023 Author Posted January 19, 2023 2 hours ago, RX400h said: Are you the original owner? Our RX400h engine uses no oil. It's oil was also changed every 4500-5000 miles with synthetic oil. Yes, I am. I switched to a 5-20W semi synthetic oil and uses a little less oil. How many miles are on your car? What kind of mileage are you getting? I am about 26 MPG average city/highway. I wonder how long our batteries will last?
RX400h Posted January 19, 2023 Posted January 19, 2023 We have about 136,000 miles on ours. I use either 5W-20 or 5W-30. Maybe a 5W-30 will slow down your consumption. I do throw in a bottle of Chevron Techron into the tank, once or twice a year. This should help with carbon buildup on valves and pistons. Mileage is 24-26 depending upon driving route. There are RX400 owners in this forum whose vehicles have over 250,000 miles on them (original battery pack).
ROBKOWSKI Posted January 19, 2023 Author Posted January 19, 2023 Thanks for the information. I will try the 5-30W on the next oil change. I trying to drive her a few more years and get a new RX hybrid then. Take care!
RX400h Posted January 20, 2023 Posted January 20, 2023 Thanks, Robert. You do the same. By the way, there's a youtube channel called "The Car Care Nut" in which a certified Toyota/Lexus master mechanic talks about all kinds of things related to the brand. He also occasionally reviews other brands. I watch his videos every so often and learn a thing or two.
David Johnson Posted April 29, 2023 Posted April 29, 2023 I had this problem with my daughter's 2017 Honda CRV. I replaced the PCV valve and problem solved. Try that if it has not been fixed by something else.
