ES 300 HAS WATER IN THE OIL AND OIL IN THE WATER
THE CAR HAS NOT RAN HOT
IM PRAYING THAT ITS A HEAD GASKET AN NOTHING ELSE
ANY REPLY TRULY APP.
Sounds like a head gasket. That is a big price job. Do a compression test to make sure. Drain all oil and coolant, flush and refill. Then do a compression test. That's what I would do.
very good advise
but you already know you have a leak
where is the only question
so if you are going to change fluids you could try bar's stop leak
or do it properly and find the leak by stripping the head off
sorry i know you would have liked a simpler answer but i think you also knew that it was going to cost big money when you first saw the problem
later
:P
You know what I would do....
Drain all fluids - refill with the stop leak stuff. Then sell the car. Shady, I know but - we've got to cut our loses. Better yet, take it to a dealership and trade it in. Don't sell it to some poor unwitting person.
Or don't listen to my shifty !Removed!. Nevermind.
  • 5 weeks later...
Don't use the stop leak stuff. I tried it and all it did was clog up my radiator and I ended up having to replace it. :(
