92Lex Posted July 25, 2004 Share Posted July 25, 2004 my ls400's moonroof only slides back a few inches. im pretty sure its not the switches because apparently its in working condition for it to slide back...right? should i just take the moonroof apart and clean/lube the rails? im a smoker so it sucks not to have a working moonroof. thanks. Quote Link to comment Share on other sites More sharing options...
VMF Posted July 25, 2004 Share Posted July 25, 2004 try to spray some WD40 on the rails b4 u dissasemble the whole setup. this solved the problem in my case. Quote Link to comment Share on other sites More sharing options...
UCF3 Posted July 26, 2004 Share Posted July 26, 2004 Don't use WD40 on your moonroof rail to clean. Our dealership uses BG Products. I'd recommend the intake cleaner to clean your rails. It has the correct amount of lubricants and moisture to clean anything. Quote Link to comment Share on other sites More sharing options...
92Lex Posted July 26, 2004 Author Share Posted July 26, 2004 can i find bg products at like, kragens? Quote Link to comment Share on other sites More sharing options...
VMF Posted July 26, 2004 Share Posted July 26, 2004 oops sorry, not the DW40, i mean i used liquid wrench. got it in the autozone Quote Link to comment Share on other sites More sharing options...
92Lex Posted July 26, 2004 Author Share Posted July 26, 2004 thanks bro Quote Link to comment Share on other sites More sharing options...
