Tranny Problems
Lexus.
My 95 LS400 tranny feels very harsh when shifting 2nd to 3rd gear. It feels like its having a spasm and doesnt feel smooth like Lexus should be.
I recently had a complete flush with Toyota type 4 from Brakes Plus.
The problem was even worse before the flush. Otherwise the car runs excellent with 110K miles. What could be the culprit of this problem? Do I need a new tranny? Would adding some liquids like dura-lube or stuff from Lucas to tranny help?
Check and see if they've overfilled the tranny.......let it get totally warmed up and check it out - too much is a bad thing. IF so, drain from the pan and replace with 1 quart less than what came out to start.......then slowly add to sneak up on it:
its a finnicky fill ;)
Hopefully they actually used Toyota Type T-IV and not Dexron/Mercon with a Lubeguard friction modifier.
In my experience I had overfilled and underfilled the tranny and a draining from the pan should drop 2 quarts and the excess if any. Refill with 2 quarts.
