GSsoldier Posted July 13, 2004 Share Posted July 13, 2004 any ever take off their exhust i hear it gives more power and sounds not much different experience welcomed so are theories Quote Link to comment Share on other sites More sharing options...
VMF Posted July 14, 2004 Share Posted July 14, 2004 depends what part of exaust you are planning to take off. it has to be carefully designed and professionally done otherwise you will loose power during the drive and engine will die at idle and your check engine light will come up. remember there are 4 o2 sensors and 3 cats there! Quote Link to comment Share on other sites More sharing options...
cel Posted July 14, 2004 Share Posted July 14, 2004 Removing part or whole exhaust system from car will enhance performance up to a point. an engine is nothing more than an air pump. most factory exhaust sytem are too restrictive, thus prevent exhaust from engine exiting fast enough. but, engines are design to have some back pressure to suck some exhaust back into engine to warm up incoming intake gas mixture to better combustion. In the end, what you need is a good aftermarket replacement exhaust system design for performance. Quote Link to comment Share on other sites More sharing options...
