customrx Posted July 11, 2004 Share Posted July 11, 2004 RX JUMPS WHEN I PUT IT IN DRIVE ONLY!!! PUT NEW SHOCK LOOKING MOUNT IN FRONT AND BOTTOM LEFT MOTOR MOUNT IT HELPED BUT STILL PRETTY BAD ..... I JUST CHANGED TRANNY BECAUS OF CLICKING NOISE IN 1ST GEAR..RAN GREAT BUT AFTER FRONT END CRASH PROBLEM STARTED... :whistles: :D Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 11, 2004 Share Posted July 11, 2004 does it do it all the time or just on start up? Quote Link to comment Share on other sites More sharing options...
customrx Posted July 11, 2004 Author Share Posted July 11, 2004 ONCE IN A BLUE MOON IT WILL GO INTO DRIVE SMOOTHLY BUT NOT NEARLY ALL THE TIME IT MAY BE WHEN IT"S COLD BUT EVEN WHEN IT"S COLD IT"S MOSTLY THE SAME..... I DROVE ANOTHER RX AT WORK AND IT WENT INTO GEAR SMOOTH AS IT COULD BE I CANT REMBER WHEN MINE WAS LIKE THAT..... Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 11, 2004 Share Posted July 11, 2004 The rx is the same engine as mine and actually all lexus start at a high idle and if put into gear to quicly while the engine is tryingto warm the tranny fluid ,engine and sensors it will bang and cause alot of wear on the parts. I never move my car without warming up for atleast a minute Quote Link to comment Share on other sites More sharing options...
customrx Posted July 11, 2004 Author Share Posted July 11, 2004 I REMOTE START MY RX FOR ABOUT 5 MINS BEFOR DRIVING IT DOES IT HOT OR COLD?THANX FOR THE QUICK RESPONSE..... Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 11, 2004 Share Posted July 11, 2004 might be the throttle cable on the throttle body , it has a little steel nub on the cable gonig to the tranny beside the throttle body it is supposed to sit a few mm out of the casing when the throttle is at idle, when not in proper alignment it causes the tranny to burn gears and hard shifting Quote Link to comment Share on other sites More sharing options...
customrx Posted July 11, 2004 Author Share Posted July 11, 2004 thanx,I am checking that today...what rpm should the rx idle at? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 12, 2004 Share Posted July 12, 2004 when hot about 600-800 Quote Link to comment Share on other sites More sharing options...
