Leather Crack Filler
~One man’s opinion / observations ~
Fill Cracks and Scratches (Leatherique Crack Filler)
For large cracks, apply flexible filler inside the crack, level with a spatula. Using damp 100% cotton towel remove filler on the surface outside the crack before it dries. Allow to air dry for thirty minutes and then wet-sand with 400 grit and a rubber sanding block. Repeat until the fill is perfectly level and smooth.
Even light scratches and roughened areas will take more than one application. Allow the filler to dry overnight before sitting on a seat that has been filled. Allow to air dry for forty-eight hours before dyeing.
Does everything they say it will
~Hope this helps~
Experience unshared; is knowledge wasted…/ Jon
justadumbarchitect * so I question everything *
  • 3 weeks later...
