Towing
dsimons
In LS400's equipped with air suspension you need to turn off this feature first before towing. The switch is located on the left side of the trunk, inside the tool box. I don't know if SC's have the same feature.
If you don't turn the air suspension feature off the computer will automatically adjust and lower air suspension as soon as the car is being angled up over 25 degrees. This will cause rear of the car to contact the ground and you don't want that to happen.
If your SC is air suspension equipped chances are there is a switch somewhere that you can turn off the feature.
