I did not have anything else to use to pry off the vent, so I used the flat head. And yeah, when I first started prying, the vinyl was getting little dents in it, but then it just regained its form , and now there is no problems. Everything looks fine.
The other tool is probably safer though.
hey 92 as long as you have the patience and hand eye co ordination
which you must then perfect
atleast you did get it out ok
i also used a flat head the first time
i had no idea on how the damn thing came out
and i spent ages looking at it
even with the lexus manual
i was erally scared as my car was only 3 years old then
pertty new to me then
Turns out that the vent is actually really easy to take out. Instead of the prying from the sides. There are two plastic stoppers at the top of the vent about an inch from the sides. So if you just stick in a stiff shim/screwdriver and push them down, the vent slides right out. Found that out accidentally after trying the sides for a long time and no being able to get it out.
Still have to breakoff the metal clips at the bottom of the vent tho.
yah the second form the bottom is the one i have sort of
it helps in many other things
as well for all those stupid clips for removing anyother trim
