Help Me Remove My Driveshaft On A 93
marmike
I've loosened the nut on the center of the shaft, removed the six bolts on the front (not sure whats its called, but its the piece coming off the tranny). The DS still wont come off. What do I do? Pry? Am I missing something?
Thanks in advance
Trust me I tried that first. The only thing I found was a page called "propeller shaft assembly" It shows everything with torque specs, but no assembly or disassmebly instructions. According to the picts (drawing) I cant see what is holding me up
I am looking at my repair manual and it does say that it can be difficult to remove. Assuming you have already removed all the bolts then the manual just says to install a screwdriver into one of the bolt holes and pry. Sorry, I would put a picture from the manual up but, I don't know how to do so. :cheers:
