20" Wheels/tire Questions
Hi,
i have a 98 GS300 and i want to put 20" wheels/tires on my car....
Now do i have to get different sizes on my front and back, (i think its called diameter or Wheel offset) can i get the same size in my fron and rear?
and what will i need to know as far as lowering..is it needed??
Thanks for any help.
This is the only thing holding me back from getting my rims so Quick help is great!!
do you have any HP upgrades? I like the light weight feel of an 18" on my trany... But to the question at hand. I have some 20"s with a 1.75 drop. If you use the correct offset you should get away with a 8.5 wide wheel upfront and up to a 10" wide wheel in back. I run a 245 on the front with a 275 on rear. Lsportline has a great ap for our car. I also love the feel and look on the new ( I hope I spell this correct ) Mahdi Caesar that is made by 5zigen.... They have a mix and match off set and sizing to bolt on with a correct fit and look. It will cost you around 4,000.00 but well worth it! Go to www.mahdicaesar.com/ts5html ;)
I do not get any rub or drag. If you are turning sharp and hit a bump you wil rub the fenders outer lip, but that is com on any low car with larger rims.....
Take it easy ( the ) LEXO
