PhillyIS04 Posted June 2, 2004 Posted June 2, 2004 Does the Twin Turbo Stock Turbo Kit from the Toyota Supra fit on to the IS300? I always thought it did but I'm not quite sure. Might sound dumb but I want to know. It's between that and getting a Kawasaki Ninja ZX-6R Bike. Thanks people.
Supra-chargedIS340 Posted June 4, 2004 Posted June 4, 2004 no it doesnt, the heads, look similer, but are quite different
TWINTURBO619 Posted June 10, 2004 Posted June 10, 2004 Does the Twin Turbo Stock Turbo Kit from the Toyota Supra fit on to the IS300? I always thought it did but I'm not quite sure. Might sound dumb but I want to know. It's between that and getting a Kawasaki Ninja ZX-6R Bike. Thanks people. the manilfold outlet is different between the ge and gte engines. you can take the head of the gte and slap it on your ge engine. the bottom end is the same with exception of the compression ratio.
Supra-chargedIS340 Posted June 10, 2004 Posted June 10, 2004 Does the Twin Turbo Stock Turbo Kit from the Toyota Supra fit on to the IS300? I always thought it did but I'm not quite sure. Might sound dumb but I want to know. It's between that and getting a Kawasaki Ninja ZX-6R Bike. Thanks people. the manilfold outlet is different between the ge and gte engines. you can take the head of the gte and slap it on your ge engine. the bottom end is the same with exception of the compression ratio. the GTE also has oil sqiuirters, and a few other small differnces
