All Activity
This stream auto-updates
- Past hour
Thanks Dave, that explains it well
- Today
MmmMercuryMetallic joined the community
RX400h started following Give me a brake , Squeaking Noise Dashboard , Mechanical Key driver's side door not working and 1 other
RX400h replied to Bill522's topic in 07 - 12 Lexus ES350
I would squirt some powdered graphite into the key hole, then make sure the key goes all the way in. As it sits right now, try lightly tapping the end of the key with a hammer. If the car starts after that, the graphite will ensure that the problem does not reoccur for a long time. -
Frank DUva started following Give me a brake
I was wondering, seeing I may be due for brake service soon, why are the rotors on the rear are solid? I'm also wondering do the rear brake calipers have a piston on both sides of the rotor?
- Yesterday
CrazyCharlieBoy joined the community
Bill522 started following Mechanical Key driver's side door not working
The mechanical key is not turning at all. I just got this car. Can I change the key and cylinder or just look for the cut code and get a new key?
Bill522 started following 07 - 12 Lexus ES350
Bill522 joined the community
For Sale: 2008 Lexus IS250 (6 Speed) $10k NEG
Lexus2501 replied to Lexus2501's topic in Lexus Buy & Sell Area
Current price has been dropped to $8k for any interested buyer. Wish I could edit my own post. -
TitanTiger09 joined the community
Looking at used gx460s and came across one that looks to be in good/great condition. 2015 64,000 miles, no accidents, seems to have been serviced regularly, etc. Dealer has it priced at $33.5鈥his is too high in my opinion for an 8 or 9 year old vehicle even if it is a gx460. question for you fine people is what do you think a fair price is? I would think $30k plus the dealers doc fee (which is always 100% profit) and taxes is fair but I don鈥檛 want to be unrealistic.
Dear Lexus drivers, I have been driving a wonderful 2010 RX 450H for about 2 months now. I look forward to sitting in the car every day and gliding along in a relaxed manner. However, there is one thing that has really been bothering me for a few days now. On uneven or bumpy roads, I can hear a "chirping" or squeaking noise from the rear part of the dashboard (driver's side). In other words, close to the windshield. Is this a known problem and are there any solutions? Video attached Greetings from Germany 20240510_162042.mp4
Eskatir joined the community
Following are the results from Microsoft Copilot: The 2007 Lexus LS460 4.6L V8 does not have a transmission fluid dipstick. Instead, it uses a check valve on the bottom of the transmission. To check the transmission fluid level, follow these steps: Ensure Safety: Park your vehicle on a level surface and engage the parking brake. Warm Up the Engine: Start the engine and let it run for a few minutes to warm up the transmission fluid. Locate the Check Valve: The check valve is typically located on the bottom of the transmission, underneath the vehicle. You may need to raise the car using a hydraulic lift or an underground bay to access it. Remove the Check Valve Plug: Use a wrench or socket to remove the check valve plug. Be cautious as some fluid may drain out. Check the Fluid Level: Insert your finger or a clean tool into the check valve hole. The fluid level should be close to the bottom of the hole. If it鈥檚 low, you may need to add more fluid. Add Transmission Fluid (if necessary): If the fluid level is low, add the appropriate transmission fluid. The 2007 Lexus LS460 requires approximately 7.7 quarts or 7.3 liters of transmission fluid12. Reinstall the Check Valve Plug: Once you鈥檝e checked the fluid level, securely reinstall the check valve plug. Verify Proper Fluid Level: Start the engine, shift through the gears (from P to 2L), and then return to Park (P). Recheck the fluid level to ensure it鈥檚 within the proper range3. Maintain Vehicle Level: Keep the vehicle level while adjusting the fluid level to ensure accuracy4. Remember to use Toyota Genuine ATF WS transmission fluid for this vehicle. If you鈥檙e unsure or need assistance, consider having a mechanic perform the check for you. Regular maintenance of your transmission fluid is crucial for optimal performance and longevity of your vehicle.
This problem just happened to my 02 SC430. What did the fix turn out to be?
Randy carlton joined the community
- Last week
2007 Lexus LS460 w/192,000 I took a 3-hour trip. While in traffic on the interstate, when accelerating in D (not manual) the engine "revs", not engaging as if in neutral. Shifted to manual to overcome, which seemed to work. Cruised at 80 MPH for 3 hours. Upon getting off the highway, the car would drive but it was as if It was starting in 5,6,7,8th gear...a very sluggish start. Shifted to Manual (1st/2nd) which did NOT work. No warning lights, no visible leaks, no smells. When shifting into reverse, I detected a "thud" or non-smooth shift. No way to check fluid since it's sealed. I am in rural Illinois--nearest dealer is 90 miles away. Called my dealer for ideas. Short of a diagnosis, not much insight. Need to make it back home which seems doable based on behavior. Thoughts?
Jim snowden joined the community
Beustace joined the community
I have a 94 LS400 and everything was working fine up until yesterday when my central locking stopped working for all my doors, the button on my key and the switches on my doors don鈥檛 do anything and the locks on the handles only lock that specific door. Any help is appreciated.
Sherie Goetz joined the community
We have a new set of dark brown, never installed carpet floor and cargo mats. It fits Lexus RX 350. 2017-2020 models. Carpet floor mat set (PT206-48161-00), Carpet Cargo Mat (PT206-48160-40). We are looking to sell the whole set for $60.00, or will sell separate, $40. for floor mats, $25. for cargo mat. Please contact us!
94 GS300. In need of help identifying a drivers side door plastic insert that mounts around locking mechanism and has a tab built in to turn off interior courtesy lights when door is closed. Picture 1 shows passenger side with insert. Picture 2 it's missing. Part # or link for me to find would be greatly appreciated, I could only find for rear doors. Thanks in advance.
Tommyg226 joined the community
navigation update for 2016 es350
ArthurW replied to Dorothy Pennachio's topic in 2013 - 2018 ES350 / ES350h
Oh nooo. How awful. 馃槦 The update process for me was in two distinct phases. The first step took about 20 minutes or so. The second step required an ignition switch off and switch on again (as prompted on the display) and then took another 6-7 minutes to complete. The SD card itself has a Lexus logo, so I assumed it was officially produced and not simply a copy by the dealer. The update reset all the settings and I had to spend some time retuning the radio, setting the navigation region, re-entering saved destinations, reloading customised images for the display, etc, etc. But all works as it should. Hope you can get it sorted. As an aside, the map is still a disappointment ... on the other hand, roads are constantly changing here in Dallas. I s'pose my obsession with having all my PCs and devices on the latest software/firmware level carried over to the car. In retrospect the upgrade didn't get me any noticeably new functionality, and I probably won't use the navigation much anyway (sticking to Google Maps on my Android phone). I'm glad it's done, but it certainly wasn't worth $215. -
tomscot2 replied to Dorothy Pennachio's topic in 2013 - 2018 ES350 / ES350h
Thanks so much. It is interesting that the Lexus online parts site does not show this item as compatible with our cars. However, I looked up which radios are GEN08 and both the 2015 and 2016 ESs are GEN08. So I bought the same part number and it bricked my system. Neither the NAV nor the radio will boot. I'm still troubleshooting, and I have a call into the Lexus dealer. The fact that it worked on your car has me believing that I turned the car off in the middle of the process at a point where I thought it was done. 馃槥 -
I just went Black w/the Ecru interior, and they look great. I sourced mine from Bell Lexus in Scottsdale (on eBay) and they were $90 plus $15 FedEx Ground shipping. Comes w/4 retention clips. OEM # PT208-24010-02. Ordered Saturday and received Thursday. Others have mentioned Sewell is no longer a source and I'm not familiar with them except through this forum, so give Bell Lexus a try. I had a good experience.
200.000 mile club, anyone else there yet?
crystalm replied to jabowsi's topic in 04 - 09 Lexus RX330 / RX350 / RX400h
We have a 2008 lexus hybrid 400h and it has 257,000 miles and still runs great! We have had to put a little money it as far as new control arms, and alignment etc. She is a great car and I hope she lasts a lot longer! -
Ohhhh Even better idea! I could mount it to the sun visor and tap into the visor light for power! Good idea? Terrible idea?
- 4 replies
- solar trickle charger
- fusebox
(and 2 more)
Tagged with:
Topics
