All Activity
- Yesterday
Jmaga joined the community
Lynn H joined the community
Geexus joined the community
goshgolly joined the community
Newdadx2 started following Headlight Problem, Low Beams not working on 2012 RX 450h
Both of the low beam headlights stopped working recently, and I can't seem to find any information that might be helpful to resolve the issue. I've checked the fuses for each side, and they are intact, do I would assume that because they both stopped working simultaneously that it would be a relay or ballast issue, and not light bulb or fuse. But I have exhausted my online search to find where the low beam relay would be located, to test and/or replace. Is there anyone who can identify the specific relay that controls the low beams? Or, am I asking the wrong question?
2007 RX 350 Hatch NOT WORKING
Paige Deaver replied to Paige Deaver's topic in 04 - 09 Lexus RX330 / RX350 / RX400h
I’m going to try all suggestions and will reply. I appreciate your efforts. Frustrated in The Ville! -
Newdadx2 joined the community
Richard K Campion joined the community
JacobC0417 joined the community
RX400h started following 2007 RX 350 Hatch NOT WORKING
RX400h replied to Paige Deaver's topic in 04 - 09 Lexus RX330 / RX350 / RX400h
Great. Patience/persistence is the key!
Ok so I figured out what the problem was. The adjuster bolt is actually seized in the pinch block. This is why I couldn’t lower the alternator enough. I ended up completely removing the lock bolt to get the alternator out, so I could get a look at it. Right now I have the car running with the alternator held in place only by the top mounting bolt being tight, hehe. I need to get a new pinch bolt, adjuster bolt, and pinch block, now…
Williemp joined the community
leedom1 joined the community
- Last week
morttorm joined the community
Thank you, AO.
Paige Deaver started following 2007 RX 350 Hatch NOT WORKING
The hatch on my RX 350 isnt working. Any suggestions?
It was Lugoff Toyota in Lugoff South Carolina. Price was a bit high but I knew that going in, $1300 ish if I remember correctly, and they did a nice quick clean job, yes I was very satisfied with them. OOps, I just noticed you were asking people in Michigan the question, Lugoff might be to far! 😁
Yeah I’ve checked out the videos. I wouldn’t post here without first checking that stuff, heh. 😛 There’s one in particular which shows a schematic and this is how I know that I’m doing the right thing (loosening the right bolts, etc.). The thing is, it seems like I can’t loosen the tensioner any more, and it needs to be looser. Tomorrow when I have some light, I’m gonna try and actually disconnect the various cables in the hopes of creating more clearance, then I’m gonna see if I can’t get the tensioner to loosen even more, because the last video I looked at seems as if it *should* get looser. This is the video btw, in case anyone ever wants to see. I think this is the best one available:
RX400h started following AC/Alternator belt replacement
Hello, Dan. Have you looked at a video such as this one?
Thank you, Frank Duva.
ephewe started following AC/Alternator belt replacement
Hey guys. So I was just outside trying to replace my AC/Alternator belt. The old one shredded itself last night, barely made it home on battery power only. New belt came today. After doing some quick research I see what is involved in getting the alternator to pivot down, in order to give me enough slack to be able to slide the new belt on. Problem is, the alternator doesn't pivot down enough and there's really no way to get leverage to pry/force it on. I'm wondering if anyone has had this problem or am I missing something? As it stands, the alternator swings up and down about half an inch, just by using my hands to lift it up and down. I am pretty sure I have loosened the adjusting bolt as much as it will let me. If I keep loosening the adjuster screw will it eventually reach a limit and then break if forced further? Because that's what it feels like..? There is basically no clearance and I'm running out of daylight, but I did remove the skirt in the front to try and get a look at the alternator from the bottom, and I just can't really tell.
I had mine done at Davis Auto Care in Northville
Thank you, AO. May I ask which dealer? Were you satisfied with the price and service?
Had mine done at a local Toyota dealer.
kevlap430 started following Timing Belt , change?
Hi all...owners of the SC in Michigan, where did you have the timing belt replaced?
DLPWMP started following Is Brake Hold available on any GX 460 models?
We're looking to buy a used GX 460 but want the brake hold feature. If it's available, could you tell us what years and trim packages it is on? Thanks!
RX400h started following Reset after replacing battery
Yes, after replacing the battery in your 2016 Lexus RX350, you will need to perform a reset to ensure all systems are functioning optimally. Here are the steps to reset your Lexus after replacing the battery: Turn Off the Ignition and Disconnect the Negative Terminal: Before you start, make sure the ignition is turned off. Then, disconnect the negative terminal of the battery1. Wait for 15 Minutes: Allow the vehicle’s systems to reset by waiting for about 15 minutes. Reconnect the Negative Terminal and Turn On the Ignition: After waiting, reconnect the negative terminal and turn on the ignition1. Reset Specific Functions: Follow the on-screen prompts to reset specific functions. This includes resetting the clock and date settings, power windows and sunroof, and the audio and navigation systems. Test the Functionality of Your Lexus After Resetting: After you’ve completed the reset, test the functionality of your Lexus to ensure everything is working properly. Please note that each window has to be reset individually. To do this, start the vehicle and roll each window down and hold for second. Also, all your radio presets will be lost and you will have to re-enter all. If you experience any issues with the functionality of your Lexus after resetting, troubleshooting options are available for common issues during the resetting process. A comprehensive test drive helps identify and address any remaining issues.
Steve8 started following Reset after replacing battery
Do I need to do a reset after replacing battery in my 2016 RX350 and how do I reset? Thanks.
RX400h started following Daytime Running Lamps
Traction control can come in handy under the following conditions: Heavy Rain, Snow, or Icy Conditions: Traction control is essential in situations such as heavy rain, snow, or icy roads, significantly improving safety. It helps prevent your car from losing traction, hydroplaning, or potentially crashing. Navigating Curves in Adverse Weather or Making Sharp Turns on Unstable Surfaces: It proves particularly valuable when navigating curves in adverse weather or making sharp turns on unstable surfaces. Driving on Slippery or Uneven Roads: Traction control should be on for most driving conditions, especially slippery or uneven roads. Sometimes a no-start (no crank) conditions indicates that the starter is failing. If the odometer is broken, how can you know for certain how many miles have been driven?
What year is your RX 350? By the way, I've found that Apple is seldom "state of the art". They still do not have an intelligent stylus. and their photo abilities are almost always a year behind that of Samsung. Perhaps it's good that Toyota/Lexus does not imitate Apple.😏
- 1 reply
- 1
Okay, I am 72 years old, but my mind is sharp...why was the shifter designed to be so confusing? I have had 10 or more Lexus' and this is the first time I have been disappointed with the car. The shifter is not intuitive...as one of my sons said, "Dad, you can tell this car wasn't designed by Apple".
I found a nice Is400 in good condition that I want to buy. The problem is that it doesn't have the traction control and heated seats package. I don't really care for the heated seats as the car is relatively low priced, but I am for the traction control. Is it necessary? Also the car doesn't start the first time. Is this something I should worry about. And the odometer has been broken for 3 years, but it's a single owner car and has serviced regularly.
Topics
