Clockspring Or Spiral Cable...which One?!?!
I have a 1999 LS400 and the horn has gone out along with the cruise control. Along with this, the airbag warning light has been on since I bought it. I cannot find a clockspring replacement part, and the only other part that is similar to this is called a spiral cable which I cannot find either.
The dealer says bring it in and they will check the switches in the steering wheel assembly...what should I do? I really want to fix this myself and save a few dollars. Thanks.
It's known officially as a Spiral Cable Assembly, but many call it a clockspring. I replaced mine in December. For me, it was just the horn that didn't work (pin 1). There are either 5 or 6 pins, two or more have lost continuity in your case. I don't know if they can be taken apart and fixed.
Here it is listed for a 95:
http://www.toyodiy.com/parts/p_U_199502_LE...5.html?hl=84306
You can create an account on that site, enter your VIN and get the exact part number for your 99.
I was fortunate to find one on eBay. Here is a current listing but unfortunately not for your model year (they're not interchangable):
http://cgi.ebay.com/ebaymotors/Lexus-LS-40...sQ5fAccessories
Here is a tutorial on how to remove the steering wheel:
http://www.clublexus.com/forums/ls400-foru...ring-wheel.html
If you go the eBay or recycle yard route, make sure you have them check continuity on all pins.
