Lexus Code Retrieval
Accessing Diagnostic Trouble Codes
The check engine warning light will come on when the ignition switch is turned On and the engine is not running. When the engine is started, the check engine warning light should go off. If light remains on, the self-diagnosis system has detected a fault in the system.
Battery voltage must be 11 volts or more. Throttle valve must be fully closed. Transmission must be in Neutral position. All accessories must be turned Off.
On pre-OBD II models, turn ignition to On, then use a jumper wire to connect terminals TE1 and El of the data link connector, located under the left hand side of the instrument panel. Codes are indicated by the number of flashes of the check engine warning light.
Reading Trouble Codes
If the ECU has detected a system malfunction, the check engine light will blink every .5 second. The first number of blinks will equal the first digit of a two digit diagnostic trouble code and after a 1.5 second pause, the second number of blinks will equal the second digit of same diagnostic trouble code. If there are two or more DTC's, there will be a 2.5 second pause between each. After all DTC's have been output there will be a 4.5 second pause and all DTC's will be repeated as long as the terminals TE1 and El of the data link connector are connected. In the event of two or more DTC's, indication will begin from smaller numbered code and continue in order to the larger. After all DTC have been recorded, remove jumper wire.
Clearing Trouble Codes
After service, the diagnostic trouble code or DTC's retained in the ECU memory must be cleared by remove the EFI fuse for approximately 10 seconds or more, depending on ambient temperature (the lower the temperature, the longer the fuse must be left out) with the ignition switch off. DTC clearing can also be done by removing the battery ground cable, other memory systems (clock) will also be cleared. If the diagnostic trouble code is not cleared, it will be retained by the ECU and appear along with a new DTC in future trouble codes. If it is necessary to work on engine components requiring removal of the battery ground cable, confirm no DTC's are stored. After clearing codes, road test the vehicle to check that a normal operation. If the same diagnostic trouble code appears, the trouble has not been corrected.
OBD1 codes:
12
RPM Signal
13
RPM Signal
14
Ignition Signal
15
Ignition Signal
16
Electronically Controlled Transmission Control Signal
17
CMP No. 1
18
CMP No. 2
21
Main O2S & Heater Signal
22
ECT Sensor Signal
24
IAT Sensor Signal
25
Air–Fuel Ratio Lean Malfunction
26
Air–Fuel Ratio Rich Malfunction
27
Sub O2S Signal
28
Main O2S
29
Sub O2S
31 & 32
Air Flow Meter Signal
35
HAC/Barometric Pressure Sensor Signal
41
TP Sensor Signal
42
VSS Signal
43
Starter Signal
47
Sub TP Sensor
48
Secondary Injection System Malfunction
51
Switch Condition Signal
52
KS Signal
53
Knock Control Signal
55
KS Signal
70
EGR System Malfunction
71
78
Fuel Pump Control
Hope this helps!
  • 2 years later...
OBD1 codes:
12
RPM Signal
13
RPM Signal
14
Ignition Signal
15
Ignition Signal
16
17
CMP No. 1
18
CMP No. 2
21
22
ECT Sensor Signal
24
IAT Sensor Signal
25
26
27
Sub O2S Signal
28
Main O2S
29
Sub O2S
31 & 32
35
41
TP Sensor Signal
42
VSS Signal
43
Starter Signal
47
Sub TP Sensor
48
51
52
KS Signal
53
55
KS Signal
70
71
78
Fuel Pump Control
Hope this helps!
How do you put a 1993 LS4 into Diagnostic mode to Read any codes if the Exist? I am having a problem with the Fuel system on the one I have just purchased.
Thanks
  • 3 months later...
OBD1 codes:
12
RPM Signal
13
RPM Signal
14
Ignition Signal
15
Ignition Signal
16
17
CMP No. 1
18
CMP No. 2
21
22
ECT Sensor Signal
24
IAT Sensor Signal
25
26
27
Sub O2S Signal
28
Main O2S
29
Sub O2S
31 & 32
35
41
TP Sensor Signal
42
VSS Signal
43
Starter Signal
47
Sub TP Sensor
48
51
52
KS Signal
53
55
KS Signal
70
71
78
Fuel Pump Control
Hope this helps!
ok i bridged mine and this is what i got.......it flashed 4 times then a slight pause and flashed once. another pause and flashed 5 times and paused once more and flashed 5 more times.
OBD1 codes:
12
RPM Signal
13
RPM Signal
14
Ignition Signal
15
Ignition Signal
16
17
CMP No. 1
18
CMP No. 2
21
22
ECT Sensor Signal
24
IAT Sensor Signal
25
26
27
Sub O2S Signal
28
Main O2S
29
Sub O2S
31 & 32
35
41
TP Sensor Signal
42
VSS Signal
43
Starter Signal
47
Sub TP Sensor
48
51
52
KS Signal
53
55
KS Signal
70
71
78
Fuel Pump Control
Hope this helps!
  • 11 years later...
Hi Paul here, I had to have my wife's 93 sc400 home. I jumped the te1 and e1 terminals and the engine and overdrive lights flash together non-stop. When I rev up the engine the tach goes to 1500 rmp then drops to zero even though the engine is still revving . Also exhaust is very rich. Any thoughts?
  • 1 year later...
Used jumperwire to connect terminals TE1 and El. Turned my ignition to on. My check engine light keeps blinking non stop. Please help.
  • 1 year later...
did you ever figure it out? having the same problem
