Hollywoody Posted September 13, 2004 Posted September 13, 2004 97' with 115,00 miles, At low speeds 40 to 50 mph car run with a skip or surge/hesitation. Anything over 50 mph running on cruise no problem. I had new wires and plugs and even ran a bottle of cleaner through system. Ran fine for a couple of days now started again. Any suggestion Thanks, Hollywoody
SKperformance Posted September 13, 2004 Posted September 13, 2004 If it ran fine after cleaning then went back to its same problem , i would suggest a pro strenght machine like a motorvac to clean the engine properly as it is probably an intake carbon build up problem
chilphil Posted March 21, 2007 Posted March 21, 2007 Changed EGR valve, fixed..... I believe that I am having the same exact issue with my car. Quick question because I want to get this right the first time.....Do I only need to buy the EGR Valve or do I also need to buy the Valve Position Sensor as well? I do not have any error reading being displayed inside of the vehicle as if the issue would be electrical. Thanks
