TRD_Altezza Posted May 28, 2004 Posted May 28, 2004 Hey ppl I am new here and I am seeking some info ASAP.. I have a JDM Altezza with the BEAMS Dual VVT-i 3S-GE 5sp Tiptronic engine (similar to the US IS300) and I bought an Aristo Vertex edition engine (US GS300).. The engine is the VVT-i version of the 2JZ-GTE engine but it has no ECU.. The only available ECU I can get now is the non -VVT-i Supra ECU.. I don't have all the $$ right now for a standalone Autronic or Apexi Power FC ECU.. So my question is would this non VVT-i ECU from the Supra run the VVT-i 2JZ-GTE?? I don't mind it the VVT does not work for the while until I buy a standalone management system or if it has to be wired up some other way to work etc.. All I need is for the engine to run smoothly and reliably.. Any sure sugestions? Or details on this procedure? Thanx in advance
Supra-chargedIS340 Posted May 28, 2004 Posted May 28, 2004 nope, the non vvti ecu will not run the vvti.........
TRD_Altezza Posted May 29, 2004 Author Posted May 29, 2004 Are you specifically referring to the VVT not working or the entire engine not working?? All I need is for the engine to run smoothly and drive..
Supra-chargedIS340 Posted May 30, 2004 Posted May 30, 2004 i highly doubt the engine will run, the ecu's use different paramiters, remember VVT means variable valve timing........ it wont be very varible if its not conected,
