Side differential seal replacement
geordeek
Thanks for the details and diagrams.  This is exactly what I needed.  I’ve changed oil seals before and they can be challenging.  Since I posted the request for info I’ve had the lexus up on jack stands to check out the leaking seal that the dealer discovered.  The so called leak is a minor weap that probably has been there for quite a while with no signs of wet fluid.  The fluid level in the dif is fine from the last service.  At this time I don’t plan to change the seal.  I will continue to monitor it and if it worsens I’ll take action.
Thanks again fot your help!
