94 Ls400 Nak --------> Alpine Deck?
kenaty
:pirate:
I wanna put a new deck into my 94 LS400 Nak audio sys. today, went to a local audio shop do the installation. they spend 2 hr then give up. the new deck will not run through the Nak AMP which comes from the factory. they say it seens i have to rewire all the speakers cause the AMP got a cross over.
my friend got a 94 LS as well. he change the deck and put it through the factory AMP. the only diff is he got a pinneer on his lexus, and he is using the radio channel to play CD. Have no idea how he did it but it works. downside is sometimes he can pick up some news when he was listen to a CD.
I was wondering if anyone can help me and give me any info or suggestion about how to install the deck to run through the AMP or how to by pass it? Any adapters? (I know very little about car audio)
if any one have the experience of installing an aftermarket deck and hookup with the original Nak sys? (I don't wanna re wire every speaker if i still have an option)
if the 95 deck mount kit fit in my 94 LS? custom make ABS mount kit is so ugly.
my A/C control some button bulb burn out.... anyone know where i can buy some?
PS. My dashboard back light not working some time. temp below 18 degree C.... it will not on. and wait about 30min warm up.... it will on. in summer time. it working fine. even the lights not working, all the meters (tacho, speed, temperature... but the gas meter is not). in the dashboard working fine. (i use a torch to see it.......) if anyone got the same problem?
if anyone have tips regarding my questions pls mail me or just reply to it. thank you very much for your help.......
I had just recently installed a alpine deck into my 91 ls, I got the dash kit and wiring harness adapter from www.sfxaudio.com, paid around $50 for everything. as far as the amp, i'll probably install a alpine M350 mono and replace the factory speaker also.
One of my bulbs on the a/c control also went out when I installed my deck, and got a replacement from the local toyota dealership, paid $5 for just the one, you will probably have to remove the burned one so they can see which one to replace it with.
:o did you by pass the AMP or Run it through? cause now if i can have the adapter then i wanna use the deck itself push all speaker...
thank you verymuch for your info... i order them now. hopefully can get it done by this weekend..
