I need to replace the cable end on the positive battery cable.  There is severe corrosion underneath the crimped portion.  It is a brass crimped connection with a 90 degree bend.   I cannot locate an OEM cable end but can locate the OEM battery terminal connection.  Anyone ever tackle this before?
You want to replace the entire positive battery cable ? And you have the OEM or alike positive battery connector ? Thanks
