Got a 04 RX330 that was in an accident. It was equipped with adaptive front headlights. Replacing with new is not cost effective. Hard to find on the secondary market. Found a standard headlight at the salvage yard. Will the existing wiring harness connect to theses? I would replace both for compatibility of course. Thank you in advance for your help.
Hi Robert.....welcome to the Club
I would imagine that the standard lamps would take a feed from the original wiring loom but the connector would be different so you would need to manually adapt the wiring to suit the new connector.
