Door lights do not go on when doors are open. Bulbs work individually but not when doors open up.
2 minutes ago, Lexus Owners Club said:
One suggestion is the door switch(s) not functioning?
How can you test that? Is there a fuse for those switches? The lights in the doors work but your suggestion is different than that. So your saying replace the door switches?
Lexus Owners Club
This post was recognized by Lexus Owners Club!
"25"
Lexigrl was awarded the badge 'Great Support'
did somehow the switch in the overhead console get turned off for the doors? my Lexus has 2 switches for dome lights. Some cars have a 3-position rocker switch to do the same functions, but the icons should be similar.
  • Like 1
That's an excellent place to start....would make perfect sense if both are not working
No I think it's the switch itself but I don't think they sell them separately from the whole unit.  Thanks
I will check that, thank you !
16 minutes ago, Lexus Owners Club said:
It could be slight corrosion on the earth contact as the switches normally earth as they screw into the pillar
I will check that. Thank you !
