Dome lights do not light up when doors open. Fuses are good and bulbs.
boggie77
2 minutes ago, Lexus Owners Club said:
One suggestion is the door switch(s) not functioning?
How can you test that? Is there a fuse for those switches? The lights in the doors work but your suggestion is different than that. So your saying replace the door switches?
Lexus Owners Club
This post was recognized by Lexus Owners Club!
"25"
Lexigrl was awarded the badge 'Great Support'
did somehow the switch in the overhead console get turned off for the doors? my Lexus has 2 switches for dome lights. Some cars have a 3-position rocker switch to do the same functions, but the icons should be similar.
  • Like 1
That's an excellent place to start....would make perfect sense if both are not working
16 minutes ago, Lexus Owners Club said:
It could be slight corrosion on the earth contact as the switches normally earth as they screw into the pillar
I will check that. Thank you !
