Hello I have a 2008 rx 400h and the master power window switch stopped working. Reading some other information on the web it appears the fuse has blown because door locks and memory seat settings are also dead. In the manual, page 359, it says the fuse is located as part of the interior fuse box however the digram shows the fuse, 79, to be outside the fuse block. Could someone please tell me where exactly that fuse is located? Thank you!
  • 4 months later...
Did you find the location of fuse 79?  I have an '08 RX400H with the same problem and I can't find that fuse location.  I have attached the page from the owner manual.
fuse location.pdf
  • 8 months later...
Has anyone discovered the location of Fuse 79?
The interior fuse box is located underneath the glove box. You will need to remove the trim and then you can see the fuse box as you lie on your back looking up below and behind the glove box. It can be difficult to spot and is about 6" x 3"
I have a 2006 RX400h, not a 2008. Where is Fuse 79 in my case?
  • 5 months later...
On 4/11/2023 at 11:25 PM, blurb said:
Has anyone discovered the location of Fuse 79? I am having the exact same issue with my 2008. I’m sick of kneeling next to my car  trying to find it.
