02 ES300 Fuel Filter Placement
JeNeViEvE
We replaced all spark plugs and ignition coils. Still throwing misfire codes and hesitating/cutting out. Checked all SP and IC's and they are functioning correctly. Next step, fuel filter. How do we get to it? Tried removing back seat, it's glued in. Please help.
9 hours ago, RX400h said:
Are you referring to a tank filter or one that's in the engine bay?
LEXUS ES300 / TOYOTA FUEL FILTER REPLACEMENT - Bing video
We can't find the one that's supposed to be in the engine bay under the air cleaner?? I think they might have stopped that one right before the 2002 model. We are just trying to find what's still throwing misfire codes and making it hesitate.
Have you seen this list of possible causes of engine hesitation/Random Cylinder Misfire Condition
P0300 LEXUS code possible causes
Faulty spark plug (s).....x
Faulty ignition coil (s).....x
Clogged or faulty fuel injector (s)
Intake air leak
Fuel injectors harness is open or shorted
Fuel Injectors circuit
poor electrical connection
Ignition coils harness is open or shorted
Ignition coils circuit poor electrical connection
Insufficient cylinders compression
Incorrect fuel pressure
Intake air leak
No. Thank you very much! So we did do the fuel pump in the gas tank under the seat. Is there another in the engine compartment? We don't see one. If there is in the 2002, can you tell us exactly how to find it, because after doing the fuel pump in the gas tank, it's still hesitating. We will also check out your list. I appreciate all of your help.
You're welcome.
You may want to call first and then possibly visit a Lexus dealership parts department. The parts person should be able to tell you (by phone), definitively if your car has a fuel filter in the engine bay. If so, he or she should be able to show you (in person) exactly where it is located and even print a copy of an exploded assembly image.
  • Like 1
