dommm Posted August 17, 2021 Posted August 17, 2021 If both the front & back brake pads were installed at the same time, which set would normally wear out first or do both wear out reasonably equal? Thanks
ElectricalEngineer Posted August 18, 2021 Posted August 18, 2021 The front brakes generally wear out first. That is one reason the brake pads are so much larger. 1
dommm Posted August 18, 2021 Author Posted August 18, 2021 4 minutes ago, ElectricalEngineer said: The front brakes generally wear out first. That is one reason the brake pads are so much larger. Thanks ElectricalEnginee
