Will wheels from later model RX 330, 350 Lexus work on the RX 300's? I know the tire size is different, but what about the offset, etc.,
Go to www.tirerack.com to see OEM sizes for each generation.
It appears the wheels will fit, since they all have the same bolt pattern. I can also find the correct tires, but I don't see any wheel offset settings. I suppose this is available from Lexus.
The tirerack picks for OEM size wheels should have the same offsets as OEM. If any doubt, give them a call. Their customer service is always top-notch.
They will also offer wider choices. You can sort by weight, cost, etc and even see what the wheels look like on your vehicle's image.
  • Like 1
Thanks, I will check
