ZambieRobx Posted April 14, 2021 Posted April 14, 2021 I can't seem to find a clear answer. I have a 99 GS300. I have a double din JVC head unit. I have sound coming out of all speakers, working just fine. I ran the radio harness to the amp harness behind the glovebox. Replaced old sub with a pioneer. I have a JL audio amp. Can I just leave the factory amp unplugged an run my JL amp straight to my head unit with RCA wires an it work fine? I've never been more confused on hooking up a system before in my life. Any answers would be appreciated
Bykfixer Posted April 14, 2021 Posted April 14, 2021 Welcome aboard Zambie. Without knowing the specifics about your JVC head unit I would say yes you can simply tie your amp to the head unit and be good to go. Without knowing the specifics of your JL amp I cannot say for certain every speaker and the subwoofer would work though. Some use a 4 channel amp where the front speakers are powered by 2 channels, the sub powered by the other two (being bridged into one) and let the head unit drive the rear speakers. If you prefer your soundstage to be from the rear use the amp to drive rear speakers and head unit the front speakers. 1
ZambieRobx Posted April 14, 2021 Author Posted April 14, 2021 Just finished installing everything today. Used the amps harness to plug into the cd player harness. Spliced the accessories wire into the grey wire from the cars stock radio harness. Ran my remote wire to the cars antenna wire. Ran my rca wires to the cd player. Works perfect 1
Bykfixer Posted April 15, 2021 Posted April 15, 2021 Woohoo!! Thanx for the update. How do you like the sound?
