cb12250 0 Posted February 14 Report Share Posted February 14 I have a 2007 RX400H and has now started to quit heating - periodically. It heats for a while then just starts to blow cold air. I have found some things on the UK site, but wondering if this is an issue in N.A. as well. Since it is -5 or better here heat is a bit important in my car at the moment. The fan blows great, and I have no other issues, and I have had heater cores go out in other cars and that is not the case. Any ideas are welcome. Quote Link to post Share on other sites
Lexus_repair 2 Posted February 24 Report Share Posted February 24 Have you tried alternating (on/off) the "auto" feature? Does it affect the heat? When was the last time your heating system coil was flushed? There is a temperature control valve also. If you don't want to go to a Lexus dealer, find a good local independent mechanic. 2 Quote Link to post Share on other sites
cb12250 0 Posted February 26 Author Report Share Posted February 26 I have done that. I usually use the Auto function - much easier in my mind. When the temperature was below 0 is when the issue happens the most. I drove today and it heated but not like it uses to. I am making an appointment with my local mechanic for a full service on it. Are there specific things I should ask them to look at? Something a bit specific would be better for a female to ask a mechanic. I get the brush off a bit with cars and women around here. Quote Link to post Share on other sites
