Just had to replace the windshield washer fluid on my 2014 Rx 350 ( after having a 70k maintenance) and discovered that the hood wouldn’t stay open? I thought it was my other RX so i proceeded to look for the “arm” none!!  What got messed up? The hood won’t stay open.
The hydraulic hood support struts are worn out.  A sign of wear is when they keep the hood up in warm weather but not in colder weather.
Here are the OEM part numbers from https://www.toyodiy.com/
SUPPORT ASSY, HOOD, RH - 53440-0E020
SUPPORT ASSY, HOOD, LH - 53450-0E010
Googling the part numbers should find both OEM and aftermarket replacements.  They are fairly easy to replace.  I've replaced several sets
